50th Anniversary Collectors Issue - September/October Issue No. 300 Preview Now
Plans & Kits
Search Plans & Kits
165 Results
Sailboats - Cruising
37' 3" Yawl, Controversy 36
Designed for strip-planking, the Controversy 36 features light displacement and good headroom, with light and open space throughout.
Construction: Strip-planked over bulkheads and frames
Lofting is required.
Plans include 16 sheets.
PUCK 550
The PUCK reflects the spirit of the original class which was to create a boat used in regattas but also suitable for coastal cruising, easy to carry and inexpensive.
Half Model Plan AMERICA 1/2 Scale
Schooner-yacht designed by George Steers and launched in 1851, the first winner of what has come to be known as the AMERICA’s Cup.
25' 9" Lubec Boat
A double-ended boat legendary for its sea keeping abilities. These plans provide very complete drawings covering everything from backbone to masthead. Construction: Strip-planked over steam-bent frames. Alternative construction: Carvel or cold-molded. Lofting is required.
27' 9" Cutter, CAPT. BLACKBURN
For cold-molded construction, a rugged cutter, popular with serious cruisers.
Construction: Cold-molded.
Alternative construction: Carvel, strip.
Plans include 11 sheets.
BRIO 555
The BRIO 555 is a fast and easy to handle boat, suitable to be sailed sportively by a crew of two or quietly and safely by a larger crew.
ROBERTS 470
ROBERTS 470 - WOOD EPOXY
The accommodation of this design has been laid out to suit two couples. The Roberts 470 makes a fine long distance cruising yacht.
Daysailer 30'
If we have to base ourselves on market demand before 2008, the two daysailers that we propose are very small. At that time, generally characterized by a continuous increase in boat size, it seemed as though a daysailer could not be less than 12 m, (even better if it exceeded 15 m).
Pagination
14' Wooden Day Sailer
For sail (sale) our whimsical 14′ day sailer “Green Flash” designed by noted small-boat designer
45' 1929 Motor Yacht by H. C. Hanson
Classic motor yacht designed by H.C. Hanson and built by Mojean and Erickson (Tacoma) for Dr.
1954 22 ft Hinckley Restored Launch
This beautiful Launch was originally believed to be built by Hinckley and was used as the yacht c
Cheoy Lee Bermuda 30
"MYRTEA" is looking for a new caretaker having not missed a sailing season over the 37 wonderful
