Sailboats - Daysailers
21' 4" Hodgdon Class Sloop
Stable, easily handled family daysailer with a lead ballast keel. Construction: Carvel planked over steamed frames. Alternative construction: Cold-molded or strip. Lofting is required. Plans include 9 sheets.
Plans Note: Scantlings are included on the supplemental material when you order the plan set.
1938 Gaff-rigged Cutter
William Atkin-designed, gaff-rigged 23' sailboat in very good shape on double-axle trailer, also
