Buckley Multi 39
Buckley Yacht Design have increased the size of the kit boat which is on offer. This 39′ Catamaran is the largest kit boat in the portfolio.
SILVER 333 is a very small classical runabout for one or two people which may easily be transported on top of a mid-size car roof.
The design of Sportfish 570 comes from a collaboration with a Senegalese society, with the aim of creating fishing vessels for inland waters of modern conception.
A boat to take you to all the shallow water places that most sailors never see up close (deep water places too). At only 95 lbs it is easily car topped or trailered and can even be launched from many places without a ramp.
Norwegian-influenced rowing/sailing craft designed for glued-lap plywood construction.
Constuction: Glued lapstrake plywood
No lofting is required.
Plans include 8 sheets.
Strip Planking red cedar building, boat with skill : light, carrellable, fashion lines.
An entry-level sliding-seat pulling boat. Provides rewarding speed in an easily built hull with enough stability to keep a beginner out of trouble. Construction: Plywood. No lofting is required. Plans include 5 sheets.
LYS stands for Lumber Yard Skiff. These rugged flat bottom work skiffs were originally designed to be built using materials readily found in most lumber yards- underlayment plywood and spruce framing.
Beamy yet fine-lined rowing/sailing boat designed for lightweight construction.
Construction: Cold-molded.
Lofting is optional.
