Launchings
If you’ve launched a boat within the past year, please email us at launchings@woodenboat.com, or post your news here.
(All posts are subject to approval and editing before being made live.)
Post your launching... or relaunching
Search Launchings
1368 Results
SOLITAIRE
Michael Lampman built the hull of this 20' MacKenzie Boats rowing scull from Atlantic white cedar wood strips covered with epoxy. The trim is Honduras mahogany. The boat, which he named SOLITAIRE, weighs only 31 pounds. Michael uses his scull on the waters near Tallahassee, Florida.
BACK BAY PRAM
Jeff Spira of Spira International wrote in to say that, “Mike Spiridonov just completed this 7′6″ pram to fish the many lakes he has up in his neighborhood. It was built using the stitch-and-glue technique [with] 1/4″ plywood, somewhat thicker than the plans originally called for.
Woods Hole Skiff
This skiff was built at the Woods Hole Historical Museum Boatshop in Woods Hole, Massachusetts, from leftover parts and materials from from other projects. It is built from BS1088 marine plywood, local black locust, red oak, and mahogany.
DOT
I began working on this Chesapeake light craft Annapolis Wherry on July 19th 2021 and launched on September 11th 2021
JOSIE
I built this Eastport Ultralight dinghy (from Chesapeak Light Craft) to get to a mooring on Sengekontacket Pond, in Edgartown, Massachusetts.
Isobune
On May 9, 2016, the Takenaka Carpentry Tools Museum in Kobe, Japan, launched this 22′9″ Isobune, a type of fishing boat developed in Tohoku, Japan. The boat was built as an exhibition at the museum by Douglas Brooks, who is a boatbuilder from Vergennes, Vermont.
Cosine Wherry
Last summer, Steve Smith launched this 14′4″ x 4′6″ Cosine Wherry, designed by John Hartsock. Steve spent 275 hours on this boat following directions from J.D. Brown’s Rip, Strip, and Row, available from the WoodenBoat Store.
SASSAFRASS 14 CANOE
Richard Knight built this Sassafras 14 canoe from a kit designed by CLC using 4 mm okoume planks, which resulted in a finished weight of just over 42 pounds. He found the lapstitch construction to work well, the hull easily came together straight and true.
Pagination
20' Surf Dory with Electric Motor and Trailer
