Sailboats - Cruising
ROBERTS SPRAY 27
ROBERTS SPRAY 27 TRAILERABLE CRUISER You can build this boat in wood epoxy and other materials too.
The FireBug is a small sailboat or yacht that you can amateur build at home, sailing club or school, then learn to sail. It's easy to sail and will be the fastest boat on the bay. Low cost too!
Resembling her 8′ cousin more than the sleeker 12′ Acorn, this chunky dinghy will be a good load carrier for her length—and she looks very, very British.Oughtred saves you from guess work by showing precisely how her planking should be lined off.Construction: Glued lapstrake plywood.Alternative c
Sandy is a husky centerboard cutter designed for extended coastal cruising in such areas as the east coasts of the U.S. or Australia, the Pacific Northwest, or Europe.
day- weekendsailer for coastal cruising in radial chine plywood construction
Didi Cruise-Mini radius chine plywood cruising sailboat
Kahuna is a superb coastal and long-distance cruising boat, designed for modern wood/epoxy construction. The first boat was built in Australia, and several have been launched in the US. Others are under construction — in the US (New York) and in Europe (Italy, the UK and Russia).
A handy clipper-bowed centerboard yawl, this boat is a heavily built, smart sailor with sparten accommodations for two.
Lofting is required.
Plans include 6 sheets.
Tandem Row & Sail | CartoppableSpecifications:
She's back! After extensive 2 year rebuild, Passagemaker is for sale!
Taffy means "Awesome" She is equipped with a 327 Chevy & ready to enjoy.
After a two year journey, My wife (Nathalie), Two sons (August and Graham) and I have completed b
