Sailboats - Cruising
Didi Cruise-Mini
Didi Cruise-Mini radius chine plywood cruising sailboat
JUNIOR, designed to compete in Diecipiedi (10 Foot) Class (www.diecipiedi.it), is norrower and therefore less stable than other boats but it is one of the fastest monohulls of the class.
Oceangoing carvel-planked cruiser with a choice of centerboard or ballast keel configurations.
Alternative construction: Strip.
Lofting is required.
Plans include 7 sheets.
MANDOLINO is an elegant, classical seaworthy small boat that we propose in two versions, one for day-sailing and one for cruising.
Compromise sloop designed by N.G.
Displacing more than 18,000 lbs, this is a big 29′ boat. She has a set of lines you can fall in love with. Construction: Carvel-planked over laminated frames. Alternative construction: Cold-molded or strip. Lofting is required. Plans include 5 sheets.
A handy clipper-bowed centerboard yawl, this boat is a heavily built, smart sailor with sparten accommodations for two.
Plans include 6 sheets.
Cutter designed by William Fife Jr., in 1888.The plans produce a model that is 28″ in length.You’ll receive 3 pages of plans historical information about the boat, step-by-step instructions and full-sized patterns for each lift, as well as template for you to shape the profile.
An oceangoing auxiliary cruiser featuring stout but simple carvel construction.
Lofting is required
For sail (sale) our whimsical 14′ day sailer “Green Flash” designed by noted small-boat designer
Classic motor yacht designed by H.C. Hanson and built by Mojean and Erickson (Tacoma) for Dr.
This beautiful Launch was originally believed to be built by Hinckley and was used as the yacht c
"MYRTEA" is looking for a new caretaker having not missed a sailing season over the 37 wonderful
