Sailboats - Cruising
Cape Cutter 19
Cape Cutter 19 lapstrake plywood trailer-sailer
The Mini Skeeter was made primarily as a fun leisure iceboat that I could use on smaller lakes. The goal I was aiming for is a small, comfortable, warm iceboat that looks elegant. The fuselage is about slightly more than10′ long. The beam is 82″.
The FireBug is a small sailboat or yacht that you can amateur build at home, sailing club or school, then learn to sail. It's easy to sail and will be the fastest boat on the bay. Low cost too!
Keel/centerboard cutter designed by Edward Burgess in 1888 and first of his “Compromise 40-footers”.The plans produce a model that is 25″ long.You’ll receive 4 pages of plans historical information about the boat and step-by-step instructions for half-hull building,using the lift method.There are
Late 19th-century skimming-dish sloop designed by Isaac P.
An expedition micro that will accommodate 2 adults for a week-end or a single-hander for up to 5 days. Ability to take on some weather and deliver solid performance while doing so. For the crew: forgiving and predictable but fast & fun. Launch time should be kept to a minimum.
The main priorities which lie at the base of the DP 14' design are: simplicity of construction, user friendliness (for single or double crew) and good performance - all of this with reasonable costs.
The Goat has become known worldwide for being a simple to build and simple to sail that delivers.
A fast and able auxiliary cruiser with wheel steering and accommodations for three.
Construction: Carvel Planked over steamed frames.
Alternative construction: Cold-molded or strip.
Lofting is required.
Plans include 5 sheets.
Based loosely on the Folkboat, this plywood lapstrake double-ender combines comforting rough-water ability, and good looks.
Construction: Lapstrake plywood over laminated frames.
Alternative construction: Traditional plank on frame, strip or cold-molded.
Hand built, One of a kind. Hull is sound, roof and rear wall of pilot house need repair.
BOAT HAS SOLD! "Thank you, Autumn. It took some time but it was well worth it." B.
Designed and built by the late Ray DeFir and his best friend, my late Step-Father, Gary Griffiths
Classic wooden rowboat (possibly Old Town).
Approximately 12’L x 4’W.
