Sea Bright 38
Parker Marine Enterprises—Sea Bright 38Length Over All: 37′ 11”Beam: 10′ 6″Draft: 2′ 4″Displacement: 9,500 lbs, half-laden (approximate)Power: Yanmar 4JH4HTE (110 hp int/99 hp cont)Water: 200 gallonsFuel: 200 gallonsAccommodations:  Sleeps four in double V-berth and two settee berths. Headroom is 6 feet on the centerline. Huge cockpit with swivel chairs and bench seat aft, including table; folding director chairs are recommended for additional seating. Anchor well forward with “rumble seat.” Fishing poles, gaffs and boathooks may be stowed under side decks in racks. NOTE: Full water & fuel tanks add over 3,000 lbs to “light” vessel weight; vessel should be operated conventionally with tanks at half-capacity unless undertaking a long cruise.Type:  New Jersey Sea Bright Power Skiff (after Banfield, circa 1928); suitable for running in coastal and offshore conditions. This model is designed with watertight floatation compartments and accommodations for four with a galley and head (including a shower). The type has an excellent record as offshore yacht and commercial fishing vessel, and can be used as an island-hopper, coastal cruiser, and ocean voyager.Construction:  Lapstrake marine plywood covered with epoxy-saturated Xynole-polyester fabric. The hull is frameless, being built over bulkheads. Skill-level required for construction is moderate to high. Alternate construction methods include strip plank and triple planked (Parker Method).
1991 Pulsifer Hampton
Well maintained Pulsifer Hampton with Yanmar 3GM for sale.
$12,500 or best offer.
