Sailboats - Cruising
Sea Bright 36
SEA BRIGHT 36L.B.P.: 36′BEAM: 10′ 11″DRAFT: 1′ 8″/4′ 7″DISPLACEMENT: 9,500 lbsBALLAST: 3,483 lbs, 2,000 lbs lead foil laminated in keel; 250 lbs trim; 633 lbs water; 600 lbs fuelWATER: 75 gallonsFUEL: 80 gallonsRIG: Gaff-rigged Cat SchoonerTYPE: New Jersey Sea Bright Skiff. Suitable for sailing in coastal and offshore conditions. This model is designed with watertight floatation compartments and accommodations for four with a galley and head. The type has an excellent record as a lifesaving vessel, and can be used as an island-hopper, coastal cruiser, and ocean voyager. This vessel is an excellent candidate for long passages single-handed.CONSTRUCTION: Marine plywood covered with epoxy-saturated Xynole-polyester fabric. The hull is frameless, being built over bulkheads. Options for planking include chine log and stitch-and-glue (Plans are drawn for stitch-and-glue). Skill-level required for construction is moderate.OPTIONS: An inboard diesel (2 cyl Yanmar 2YM15) may be installed under the forward end of the cockpit well as shown. An outboard in a well is also possible for this model. Permanent ballast consists of lead foil laminated inside the keel bottom on both sides of the CB trunk covered with ¼″ teak & holly plywood. Standing headroom is 5′ 10″. Additional rigs are available on a custom-design basis.
20 sq.m/ Dragon class
Dragon class was first designed by the Master designer Johan Anker as a 20 sq.m.
BUD
Rowing version as tender to La Vie en Rose.  Modifications include laminated frames instead of th
