Oar / Paddle
Outboard Skiff, Sprite
An outboard skiff with a wide bottom and moderate rocker that contribute to stability and the ability to carry weight back aft.
  • Construction: Cross-planked bottom, lapstrake sides
  • Alternative construction: Plywood or glued-lapstrake plywood
  • Lofting is required
  • Plans include 4 sheets.
  • Order the plans directly from our WoodenBoat Store Site
  • Or you can order the individual study plan as a PDF file. Just Click: Digital Study Plan
2012 40' Gartside Yawl
This gorgeous Bermudian Double Ended Yawl ‘La Vie en Rose’ was designed by Paul Gartside, built b
Penobscot 14
Thia is an Arch Davis design, nicely built. An excellent boat under oars or sail.
