Sailboats - Cruising
North Sea 29
The North Sea 29 is a centerboard boat designed for sailing in the rough North Sea. She’s a fairly heavy displacement boat that will prove a very capable ocean cruiser. She offers excellent stability and performance, while the centerboard will make it easy to escape crowded anchorages or explore shallow cruising grounds.
Plans for the North Sea 29 include computer generated offsets with no lofting needed. No building molds are used — four laminated ring frames plus bulkheads provide the mold over which the strip planking is fastened. The strips are then covered by two layers of 1/8″/3mm veneer.
A Bermudan rig is available as an option, as is a steel ballast box that simplifies the ballast pour. Beckon, the first NS29 to be launched, is off cruising (in Mexico as of early 2021), and another boat is building in Belgium.
Cheerio II
Cheerio II, 1931 46' yawl, formerly owned by actor Errol Flynn.
Great Lakes Class sloop
Built by the Burr Bros in 1960, this 36' beauty with a 10'9" beam was restored over seven years a
