Oar / Paddle
Egret: A Wetlands Punt
Here is a fine little working type punt that feels at home in the marshlands, as well as the open bay waters.She is 14'-9" long and was designed around a working load, with a draft of about 3". The nice flare of her sides gives good stability and the generous beam of 54" allows for a comfortable 48" rowing station. A short skeg keeps her tracking when rowing or punting. The decks are well crowned and the coaming will keep you dry in choppy conditions! There are removable floor boards and a storage rack under the afterdeck. The narrow transom offers stability and more displacement is using a small gas or electric outboard. Approxcimate weight is 200 lbs and she is easily trailable. Primary material calls for a 1/4" and 3/8" marine grade plywood and glued epoxy construction is ideal. No full size lnd steps to take for building.  Plans are $95.00 by check or money order and a builders agreement is available for professional builders.
Shaw 24 for sale
William Shaw design, 24' Yawl with shoal keel and centerboard, built 1958 in Denmark.
12' Beetle Cat
12' Beetle Cat with sail rig. Boat needs new ribs. Planking is good. Asking $500.
